mikeh78
Dec 20, 2024Aspirant
wax630 web interface white screen
I purchased the WAX630 for home use (yes overkill). I changed my access point setting for client isolation and saved changes. The web interface hung and now the login screen is just a white screen....
- Dec 21, 2024
I've done a factory reset numerous times. And would run through the setup.
This time I changed the SSID, IP, etc. to all new names and range instead of what it was previously and it's working now. The other difference was it was shutdown for the night, not sure if this makes any difference or not (shouldn't)? But at least it's working.
Thanks for your reply. 🙂
schumaku
Dec 21, 2024Guru - Experienced User
Hello mikeh78
Attempting to access the WAX630 from a wireless client after a having enabled the Client Isolation for the wireless network in question? Tempted to state this works like intended....
A factory reset and new config from scratch will recover 8-)
-Kurt.
- mikeh78Dec 21, 2024Aspirant
