jjsmd
Dec 03, 2022Aspirant
WAX630E and Orbi 960 series (RBKE963
Hi I have a WAX630E root and one extender (also WAX630E) my question is cn I add a RBKE963 to the system? will it be manageble via insight? will it pair with each other? Thanks for any info
- Jan 25, 2023
The wired WAX630E will become a root automatically with the Mesh mode enabled.
schumaku
Jan 05, 2023Guru - Experienced User
Of course it has. Netgear has introduced insight instant mesh https://kb.netgear.com/000064930/What-is-Insight-Instant-Mesh The Orbi 960 mentioned isn't involved.
jjsmd
Jan 25, 2023Aspirant
Thank you for your reply.
As far as setting up mesh system, if I have 3 WAX630 equally spaced it only one location has Ethernet cable, does that one need to be setup as root or can one of the others be “root”?
- schumakuJan 25, 2023Guru - Experienced User
