jjsmd
Dec 03, 2022Aspirant
WAX630E and Orbi 960 series (RBKE963
Hi I have a WAX630E root and one extender (also WAX630E) my question is cn I add a RBKE963 to the system? will it be manageble via insight? will it pair with each other? Thanks for any info
- Jan 25, 2023
The wired WAX630E will become a root automatically with the Mesh mode enabled.
jjsmd
Jan 25, 2023Aspirant
Thank you for your reply.
As far as setting up mesh system, if I have 3 WAX630 equally spaced it only one location has Ethernet cable, does that one need to be setup as root or can one of the others be “root”?
schumaku
Jan 25, 2023Guru - Experienced User
