diehardbattery1
Jan 11, 2023Guide
WAX630E Best connection method for 2 AP's at same location?
I have 2 WAX630E AP's in my home. While it might seem overkill, I have a single story 3800sqft home, and figured one at the front of the house and one at the rear would provide the best coverage/spe...
- Jan 12, 2023
schumaku wrote:Undoubted, this is where I would bring a MS108EUP uplink port so you have a consistent 2.5GbE coverage.
It's not a question of 6E - the same would apply if operating 5 GHz AX on a 4x4 or for the sake on 2x2 clients. The performance would not massively differ if not having the 4x4 in 5.0GHz H, 4x4 in 5.0GHz L, 4x4 in 2.4GHz radios on board (5.0GHz H: 2400Mbps, 5.0GHz L: 2400Mbps, 2.4GHz: 1200Mbps) instead of the 2x2 in 6.0GHz, 4x4 in 5.0GHz, 2x2 in 2.4GHz radios (6.0GHz: 2400Mbps, 5.0GHz: 4800Mbps, 2.4GHz: 600Mbps). Needless to say, the dedicated 6 GHz channels provide an advantage due to the much less occupied band.
The powerful AP could take big advantage on the 2.5GbE vs. the limited single Gigabit uplink.
I have arranged it so the MS108 is directly connected to the appliance so the 2.5G is fully realized, and the Gigabit switch uplinks to that. I did not notice any difference until I realized I never went and enabled 6G on the AP. Once I did that, all was good.
diehardbattery1
Jan 11, 2023Guide
schumaku wrote:The question is what you want to achieve with this two AP on the 2.5G links each and the rest of the infrastructure which remains on Gigabit.
I have 6E devices. I upgraded from the Orbi 6E mesh system (not Pro), so I was trying to match what I had or do better. The question I could not find a solid answer on was if 2.5G was needed to achieve 6E performance. With the Orbi, I had no 2.5G links and was able to get full speed on my 6E devices, whereas now I am only getting about half of that with the mesh setup. I was getting a bit less than half before I created the Insight mesh. I also have a firewall appliance with 2.5G ports (WAN, eth0, opt1, opt2). Despite the seemingly obvious mistake I might have made by connecting the MS108E to a 1G switch, should I have instead connected to the appliance?
schumaku
Jan 11, 2023Guru - Experienced User
- diehardbattery1Jan 12, 2023Guide
