kitor
Nov 09, 2024Aspirant
WAX630E cross-VLAN traffic still broken after over a year since Netgear is aware of the bug.
There's this nice topic that I can't reply on: https://community.netgear.com/t5/Business-Wireless/WAX630E-VLAN-bug/td-p/2325009 So I'm running on the latest firmware - V10.8.10.10 in standalone ...
VinceDucat
Dec 07, 2024Tutor
I have the same probleme device in 2 ssid with different vlan on the same wax630e cant talk eahother
i have pfsense as firewall and rule are ok ...
what is the workaround ? changing wax630e to wbe710/750 the only solution ?
kitor
Dec 07, 2024Aspirant
If you need a workaround, you can put some kind of proxy in between (even for TCP conns you can run haproxy in TCP mode). I've done exactly that, but this is BS it is even needed.
As for ReneD - this device doesn't come from official Netgear distribution, so I am not likely to get any support.
On the other hand I talked with a friend who is a major OpenWRT contributor and he expressed his potential interest in porting to this device.
This is pretty sad as except this tiny issue I am actually happy from this device performance. It just crashes previous Cisco Meraki APs I had.
- VinceDucatDec 07, 2024Tutor
kitor haproxy is a pakage of pfsense right ? so can you develop how to put in place and setting up haproxy ?
sorry i dont undestand "BS" ... ! perhaps due to my poor english đ
- BrianLFeb 05, 2025NETGEAR Moderator
HI kitor VinceDucat,
Welcome to the community!
Unfortunately, we do not have a workaround for this issue but replacing them with WAX630 or WBE710 as my colleague suggested, is the next best course to resolve this issue.
Kind regards,
BrianL
