DanBlackaz88
Sep 26, 2023Tutor
WAX630E Mesh / Channels etc
Hello, This might seem like a basic question but I want to check what the correct answer is. I have 2 x WAX630Es installed - both are Insight managed and both are POE connected into the netwo...
- Sep 26, 2023
I've just seen this Article:
What is Insight Instant Mesh? - NETGEAR Support
That suggests that having WIRED WAPs on the network DOES NOT need any Mesh turned on and you only turn that on if you have upto 4 WAPs connected to one of the wired WAPs via a wireless backhaul - is that right?
DanBlackaz88
Sep 26, 2023Tutor
schumaku
Sep 26, 2023Guru - Experienced User
Fore pure wired backhaul no Mesh must be enabled. Leave it on Auto, or for security consideration, I would suggest to select:
Disable Mesh - AP does not mesh with other APs.
