OneGigMan
Oct 30, 2022Aspirant
WAX630E not outputting Wifi 6E
I have an Xfinity XB8 Tri-Band modem that outputs WiFi 6e. I added a WAX60E access point, but it's not outputting Wifi 6e E....just wifi 6. Attached are my settings for that SSID. Can anyone help me o...
OneGigMan
Oct 31, 2022Aspirant
The WiFi indicator on my phone only shows "6" not "6E" like it was before I added the access point
Oct 31, 2022Guru - Experienced User
1. what phone do you have?
2. Is it connected to the access point?
3. Do other devices not see the 6gh?
4. If you disable the 2.4ghz/5ghz signal, does the phone still see the network?
5. Are you using bandsteering? Single ssid function?
- OneGigManOct 31, 2022Aspirant1) Samsung Gakaxy S22 Ultra (6E compatible)
2) It is connected to the AP on 5ghz
3) I have no other devices 6ghz compatible
4) I've added a 6Ghz SSID on the AP, disabled 2.4 and 5ghz on the AP, my phone does not see it at all. Instead it connects to my routers 6E signal now.
5)Band steering is off and not sure what single SSID function is.
