tigo013's avatar
tigo013
WAX630e redundancy
Writing to get some thoughts on this.   AP 1 - connected to Switch 1. AP1  is powered via PoE++. (STP is enabled) AP 2 - connected to Switch 2. AP2  is powered via powered adapter. (STP is enabled...
  • tigo013's avatar
    tigo013
    Apr 14, 2025
    Hi Katherine,
    Thank you for your thoughts. Standard practices is the way to go! Until I can sort out a permenant switch-port for that AP2, I've simply disabled the Wireless bridge from AP1. As and when the need arises that AP2s' ethernet cable is disconnected, I'll re-enable the Wireless bridge from AP1.
    Usually, the ethernet cable disconnection from AP2 happens to sort out that things that arise, and a couple of days later I'd be able to re-connect it. I'll add a note on the cable to remind myself to enable the bridge on AP1. The bridge configuration exists and will remain in-active on AP2. So whenver AP1 is enabled - the bridge will come alive.
    cheers,
ProSupport for Business
