ivant088
Aug 20, 2022Aspirant
WAX630E slow when managment lan is changed
Wifi speed on the WAX630E slows to around 40mbps on both upload and download when management lan id of the access point is changed. If it is left as 1, speed is normal. Previous access point from a d...
RaghuHR
Aug 22, 2022NETGEAR Expert
This is getting addressed in our next release. Please wait for next month release.
Raghu
bamhm182
Sep 11, 2022Tutor
Still having these issues. I am on 10.2.0.17. Is it expected for this to have been resolved yet or is the fix still coming?
- ivant088Sep 11, 2022Aspirant
10.2.0.17 didn't fix the issue for me either. Even tried a full reset and reconfig after firmware update.
- RaghuHRSep 11, 2022NETGEAR Expert
Hi ivant088
Also we need to know:
- untagged VLAN configuration.
- whether a DHCP server is configured and running in the untagged VLAN in the network.
Also send me via PM your config back up. We will check and revert.
Thanks,
Raghu
- ivant088Sep 12, 2022Aspirant
WAP management vlan set as non default and tagged. (Unchecked the untagged vlan checkbox)
Static IP for WAP
No DHCP server on management VLAN
