ftlnparis
Oct 21, 2022Star
WAX630E Very poor IPv6 performance
Hi All, My WAX630E is not playing well with IPv6. Lots of TCP retransmissions for traffic coming through the WAX630e when IPv6 protocol is used, IPv4 traffic comes through the AP just fine. ...
- Nov 08, 2022Beta firmware has definitely fixed the slow IPv6 performance.
Hopefully Netgear will incorporate this fix in their next release.
Big thanks to to Tomasz from Netgear support team for excellent support and updates, his bosses should definitely give him as pay rise as workers like him give a good impression for the company.
ftlnparis
Nov 07, 2022Star
UPDATE 8th of Nov 22
Ticket status:
- Opened ticket with Negate support.
- Ticket acknowledged very fast by Netgear (within the hour).
- Higher tier engineer has taken on the case and has requested logs, activation of reverse ssh to Netgear servers, and packet capture.
- Awaiting feedback 26 Oct 22
- Still awaiting feedback 27 Oct 22
- Feedback provided from Netgear that issue has been reproduced and they are investigating the root cause 2nd Nov 22
- 8th November, feedback from Netgear that root cause of bug is fixed in beta firmware. I have installed beta firmware and confirm that on first impression that bug no longer exists, will try for a few days longer to check for stability.
ftlnparis
Nov 08, 2022Star
