CrownITSupport
Aug 14, 2019Follower
WC9500 Unified SSID question
Hi, We using a WC9500 controller with many access points. We using separate SSID for 2.4G and 5G but they are the same across the whole range of AP's. Is there a possibility to set up the same SS...
- Aug 21, 2019
Hi CrownITSupport,
Welcome to our community! :)
Unfortunately, Unified SSID is not yet supported for a wireless controller. It could be better if you will post this on our Ideas Exchange for Business board so that our engineering team may consider it.
JohnCarloV
NETGEAR Community Team
JohnC_V
Aug 21, 2019NETGEAR Employee Retired
Hi CrownITSupport,
JohnCarloV
