GSomma's avatar
GSomma
Initiate
Jan 09, 2024
WG302v2 does not fit into VLAN
I have an old WG302v2 Access Point that I only use for testing. I have to use it now with VLANs. If I reset and use a normal unmanaged switch I can access and configure it. If I plug it into a man...
  • schumaku's avatar
    Jan 09, 2024
    Start about here:
ProSupport for Business
