vickyd48's avatar
vickyd48
Follower
May 02, 2018
Which AP should I get
What is the best AP for the following configuratio?     WAN - IP is not really public, but has access to our Internal LAN and Internet LAN - IP's will be provided by DHCP or static but differnt...
  • DaneA's avatar
    May 03, 2018
    Hi vickyd48,
    Welcome to the community! :)
    You may want to check the WAC510 - Insight Managed Smart Cloud Wireless Access Point.  The WAC510 can function either as AP mode or Router mode.  If AP mode is selected, it functions as a standalone access point.  If the Router mode is selected, it functions as a standalone AP with its router functionality enabled including network address translation (NAT) and the option to enable and configure the DHCP server of the access point.  Kindly read page 114 of the WAC510 user manual here.
    DaneA
    NETGEAR Community Team
No content to show
ProSupport for Business
