Toonlord
Apr 23, 2023Aspirant
Wireless Access Point control panel not reachable after changing admin password
I am trying to set up a NETGEAR WAC104 AC1200 Dual Band Wireless Access Point and it requires me to change the admin password before I can do anything in the console. The problem is when I do make the...
- Apr 26, 2023No I don't have access to the room the router is in. I am a tenant in the house so I can connect and have admin access to the network but the router is in the landlord's apartment. I came up with a work around using a wifi extender with a network port to connect the ap to. The router/modem is a docsis 3.1 cable modem router(coda-4589). It wasn't quite what I was hoping for but it works.
michaelkenward
Apr 25, 2023Guru - Experienced User
Toonlord wrote:
I just realised that the powerline internet thing is one of those ones that transmit through the cables
What cables?
You mean you can't plug things into the mains electricity circuit?
To use the WAC104 as an AP, as it was designed, you can use a Powerline plug next to the router. (I assume that you have access to that.)
You plug the Powerline plug into a mains socket near the router. Then connect plug and router with an Ethernet cable.
You then plug another Powerline plug into a mains socket near where you want to use the WAC104. Then you connect the WAC104 to the Powerline plug with an Ethernet cable. The WAC104 then covers the area with WiFi.
Did you ever tell us what the router is at the heart if your network?
Did you investigate the bit in the manual about WDS?
Toonlord
Apr 26, 2023Aspirant
