bfb
Sep 10, 2022Aspirant
Abbruch der Verbindung
Hallo, ich habe einen MR 1100 und hatte von Anbeginn an Probleme mit dem Gerät. Wenn der Akku drin war, überhitze der Router. Nach Rücksprache mit dem Support, sollte ich, der Router ist in einem Woh...
microchip8
Sep 10, 2022Master
Cool story, bro!
Now in English
Now in English
- bfbSep 12, 2022AspirantHello,
I have an MR 1100 and had problems with the device right from the start. If the battery was in, the router would overheat. After consultation with the support, I should, the router is installed in a mobile home and is connected to permanent plus, remove the battery, since the router also works without a battery. So far all good. However, I have the problem that the router loses the connection to the Internet after an indefinite period of time, which is not understandable. The LED is still blue, but a connection is no longer possible. If I restart the router, the connection is immediately restored.
Anyone know advice??
