MarSch1975
Dec 23, 2021Aspirant
M1 Ladeproblematik und schlechte LTE-Empfang
Hallo, ich habe das bekannte Problem das der Router den Akku nicht läd weil er laut Menü 45 Grad warm ist, das kann gut sein weil er sich auch wärmer als Körpertemp anfühlt in meiner Hand, also d...
Dec 23, 2021Guru - Experienced User
Englisch Bitte
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
- microchip8Dec 23, 2021Master
Do you speak English, mofo?
- MarSch1975Dec 23, 2021Aspirant
@FURYYe38
Thanks, I used the mobile forum...
When I entered the forum I saw some german topics so I thought german is fine too, sorry for that.
BTW: Is that the way this forum works? Using "mofo" like "microship8"?
- FURRYe38Dec 24, 2021Guru - Experienced User
MarSch1975 wrote:
@FURYYe38
When I entered the forum I saw some german topics so I thought german is fine too, sorry for that. This forum is in English. If you find the German mobile file, you of course can post in native language.
BTW: Is that the way this forum works? Using "mofo" like "microship8"? No. That woudl be innapropriate.
