UweK's avatar
UweK
Tutor
Mar 21, 2021
NIghthawk M1 Battery bloated
Hello,
today I checked my camper where I have the Nighthawk installed for internet access while travelling.
When checking the router I found the battery was bloated, the router itself not showing any errors.
As this does not look right, I took the battery out for the time beeing.
Question : where could this come from and would it be save to continue using the battery ?
Many thx in advance.
Uwe
  • Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
1 Reply
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Dear Customer,
    Kind Regards,
    DamianM
    NETGEAR Community
