LaurentG's avatar
LaurentG
nighthawk M1 wrong DNS for Guest network ?bug?
Hi, I have the following lan setup for my router: IP 172.102.4.1/24 DNS 172.102.4.253 DHCP enabled   When devices connect to 2.4 or 5 GHz WiFi they get the correct IP and DNS. When devices con...
  • DamianM's avatar
    Mar 09, 2021
    Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
