kagey60
Jul 05, 2023Follower
GS324v2 all port speed LEDs flashing amber
Hi all, Can anyone help please? I have a GS324v2 unmanaged switch on a home network which is only 6 months old, and was working fine. Today, ALL of the Port Speed LED's are flashing amber, the ...
schumaku
Jul 21, 2023Guru - Experienced User
Today, ALL of the Port Speed LED's are flashing amber, the Power light is flashing green and nothing appears to be working.
Is there any way to reset it to the factory default, or similar? I can't seem to find out what the flashing lights mean, let alone obtain any help as that appears to be non-existent 3 months after the purchase date!
This switch does come with 3 years warranty, except for mainland China (check the SOHO Gigabit Unmanaged Switches 300 Series Data Sheet ). Head to https://my.netgear.com/ , ensure your switch is registered with it's serial number, view the product in the list, and follow the [Request hardware support] process.
Machen Sie mit!
ProSupport for Business
