Stefan87
May 17, 2025Aspirant
Wax 615 seit kanal Wechsel von 36 auf 64 verbindet sich ein android Telefon alle 12h neu
seit einen kanal Wechsel von 36 auf 64 verbindet sich ein adroit Telefon alle 12h neu motog22 alle anderen Geräte laufen länger wie 12h durch und sind alle mit dem selben dhcp und mac filter ipf...
Stefan87
May 17 10:27:34 nddmp[4937]: alarm : seqNo-[231], level-[OTHER], info-[{"ip":"192.168.1.53","mac":"C0-6B-55-E3-7C-31","hname":"moto-g22","txR":"390 Mbps","rxR":"433.30 Mbps","ssid":"Green 5 ghz ax","dOs":"Generic Android","dType":"Mobile/Tablet","mode":"11AC","status":"Authenticated","bssid":"C8-9E-43-28-33-C1","chnl":"64","chWidth":"160 MHz","rssi":"32","state":"QOS/HT/VHT","type":"wpa3","idle":"0","time":"00:00:01","txB":"8070","rxB":"18852","pmf":"none","vlanID":"1","Username":"Not Applicable","radio":"1"}]
May 17 10:27:33 nddmp[4937]: alarm : seqNo-[230], level-[INFO], info-[Netgearaxgreen: moto-g22 (C0-6B-55-E3-7C-31) connected to Green 5 ghz ax with an RSSI -61dBm]
May 17 10:27:33 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 WPA: pairwise key handshake completed (RSN)
May 17 10:27:33 configd[4709]: 18391: error in fetching sta details for mac = C0-6B-55-E3-7C-31, iface = wifi1vap0
May 17 10:27:33 configd[4709]: Authentication Failed for client C0-6B-55-E3-7C-31
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 WPA: received EAPOL-Key frame (4/4 Pairwise)
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 WPA: sending 3/4 msg of 4-Way Handshake
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 WPA: received EAPOL-Key frame (2/4 Pairwise)
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 WPA: sending 1/4 msg of 4-Way Handshake
May 17 10:27:32 hostapd: handle_assoc_cb: Marking client's assoc state as 0
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: associated (aid 4)
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: SAE: Sent Confirm
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: SAE: Received Confirm
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: SAE: Sent Commit
May 17 10:27:32 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: SAE: Received Commit
May 17 10:27:31 nddmp[4937]: alarm : seqNo-[229], level-[INFO], info-[Netgearaxgreen: moto-g22 (C0-6B-55-E3-7C-31) disconnected from Green 5 ghz ax]
May 17 10:27:31 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: Station deauthenticated due to reason code 3
May 17 10:27:31 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: disconnected
May 17 10:27:31 hostapd: wifi1vap0: STA c0:6b:55:e3:7c:31 IEEE 802.11: disassociatedHier der log
Machen Sie mit!
ProSupport for Business
