CorleoneL
Nov 19, 2021Follower
CM2000 in Deutschland nutzbar?
Hat jemand den CM2000 im Einsatz und kann bestätigen, dass dieser in Deutschland funktioniert? Danke.
Deborah2323
May 08, 2022Aspirant
DamianM
Can you provide instruction on how to set up the Netgear Nighthawk CM2000 for use in Germany? Thank you!
DamianM
May 10, 2022NETGEAR Moderator
Hi @Deborah2323,
because we don't support the CM2000 in Germany I cannot provide you any instruction how to install the device.
With kind regards,
Damian
NETGEAR Team
