Christian1977's avatar
Jan 09, 2021
FW 2.6.1.40 LAN connection not working
Hi there
Since the update I am not able to wire connect devices with my Orbi at all.
Orbi is set up in Router Modus and 2 satellites are wire connected. Also the satellites are sometimes loosing the connection.
Update process
1. Update First RBS
2. Update second RBS
3. Update RBR
Has anybody an idea how I can solve this?
Is anybody having similar issues or knows about?
Thank you
Christian
  • Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
1 Reply
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Dear Customer,
    Kind Regards,
    DamianM
    NETGEAR Community
