wittgenstein
Feb 01, 2020Aspirant
Netgear Armor and Chromebook
I have a new Orbi system and installed Armor on one device - an Android phone.
The other main device I need it for is my Asus Chromebook - but all I get from the Chrome Store is error messages saying "this version" of the app (apparently the only one?) is not compatible with my device.
Can I use Armor on a Chromebook or not?
Thanks!
Hi wittgenstein, welcome to the community! The Armor apps are primarily designed to work for the mobile Android OS. There are helpful links on the Internet and here are some that you can check.
https://www.digitaltrends.com/computing/how-to-get-android-apps-on-a-chromebook/
https://mashtips.com/install-android-apps-amazon-kindle-fire/
Dexter
- wittgensteinAspirant
It gets weirder.
(1) After being told that my Chromebook is not compatible with the available version of Armor, and *NOT repeat NOT* actively doing anything to download it, I discover that it *has in fact been been downloaded and is active on this dervice.*
(2) I then tried to activate it on my Kindle Fire and ... was told it is "not compatible with this device." Maybe now it will mysteriously show up there too! Maybe not!
For a supposedly transparent and user-friendly security system, this is is so far not inspiring confidence. Can anyone explain this?
- DexterJBNETGEAR Moderator
Dexter
