stefan_net
Dec 16, 2021Follower
Orbi AC3000 - Satellit Add-on compatibility
Hello to all,
i have a RBK53 AC3000 Set in my house and i need more satellits.
The first questitons: Is AC3000 and AX1800 or AX4200 compatible?
And the second: How much satellits i can add-on by an AC3000 system?
Thank you!
Stefan
- DamianMNETGEAR Moderator
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
- SWLGLuminary
1. https://kb.netgear.com/000061570/Are-older-Orbi-WiFi-satellites-compatible-with-Orbi-WiFi-6-Systems
Der Artikel erklärt, dass ältere Orbi-Satelliten (AC) mit den neueren Orbi-Systemem (AX) nicht kompatibel sind.
2. https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
Der Artikel erklärt, wie viele Satelliten man insgesamt haben kann.
