goshy
Sep 22, 2022Aspirant
Satelliten werden bei aktivierter Zugriffssteuerung vom Internet ausgeschlossen
Hallöle, ich habe das Problem, dass Satelliten bei aktivierter Zugriffsteuerung vom Internet abgeschnitten werden. Wenn ich über den Router im Wifi bin läuft alles, sobald ich einen anderen Raum ...
ekhalil
Sep 23, 2022Master
goshy wrote:Hallöle,
I have the problem that satellites are cut off from the internet when access control is activated. If I'm in Wifi via the router, everything works, as soon as I enter another room and the mobile phone uses a satellite, I have Wifi without Internet, I can still access the router via intranet. If I disable access control everything works. My system: RBR50v2 2x RBS50v2 1x RBS50 (Maybe this is where the problem lies?!) Firmware is currently 2.7.4.24 on all devices. No modem in front, have fiber optics enabled with VLAN. I can't enter the satellites via MAC in the access control, double MAC error, i.e. the router has already entered the MACs, it would be pretty stupid if not.
It seems that the Access Control settings were never propagated correctly to the satellites (or some satellites).
- Please make sure all satellites are connected and the connectivity is stable (green/good in the app and web GUI attached devices).
- On the web GUI (orbilogin.com), go to >> ADVANCED >> Security >> Access Control, and check all devices and click on Allow, also uncheck "Turn On Access Control". Then click on Apply.
- Now, if you want Access Control to be on again, go back and check "Turn On Access Control" and click on Aplly again.
