Luca05
Sep 28, 2021Follower
Nighthawk x6 ex7700 drops connection to other devices
Since i connected the Extender with my Router, the wifi is bugging around. On some devices it shows no connection but it is connected to the wifi and you can use the wifi normally. Other devices aren't even seeing the wifi anymore on the list. And other devices see the wifi but can't connect to the wifi. Im using the Nighthawk x6 Ex7700 wich is connected to an Huawei Ax3 Router.
1 Reply
- DamianMNETGEAR Moderator
Dear Customer,
You have contacted the German-speaking NETGEAR Community.
We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
Kind Regards,
DamianM
NETGEAR Community
