witchhunt
Aug 26, 2024Aspirant
Unterstützung
Hallo Community, ich habe mir im Juni 24 einen gebrauchten Nighthawk x6s AC3000 über ebay gekauft und möchte ihn jetzt als Repeater in mein Netzwerk einbinden. Er ist natürlich auf einen Vorbesitze...
witchhunt
Aug 29, 2024Aspirant
I bought a used Nighthawk x6s AC3000 on ebay in June 24 and would now like to integrate it into my network as a repeater. I want it to send the electricity meter data to my router via wifi. From there it should then send it to Lumentree using the Trucki stick. I have already restored the factory settings for admin and password for logging in. But it does not work. I have also tried using the cell phone (QR code) without success. The free support has expired.
What can I do?
Kind regards
Aug 29, 2024Guru - Experienced User
AC3200 is a speed. Not a model.
What did you buy?
What fails during setup?
- witchhuntAug 29, 2024Aspirant
I have purchased the Nighthawk x6s AC3000 and would like to integrate it into my network as a repeater.
- plemansAug 29, 2024Guru - Experienced User
Thats a speed. Not a model.
Look at the label. What model did you buy?
And where is it failing in the install process? Screen snips and complete details help more than being vague
sorry i need a little longer to answer, i live in germany and speak german. these translations are provided by deepl.com.
fails : I cant log into the Nighthawk with the standard data
