Tushard3094
Oct 03, 2018Follower
Internet is not working.
I have the Netgear r6220 AC1200 router. The connection from the modem to the laptop is working perfectly well but when I am connecting it to the Router and then connecting my laptop with LAN or Wifi, ...
Slas
Oct 05, 2018NETGEAR Employee Retired
Hello Tushard3094,
and welcome to the NETGEAR community.
Check the IP configuration on your laptop.
Your laptop must be in the same IP range as your router.
Does the R6220 work in router or AP mode?
Which modem do you have?
Best regards,
Slas
NETGEAR Community Team
