mschnrm
Jun 23, 2022Aspirant
R6400v2 updated nicht mehr
Habe mehrmals versucht den router ueber die app nach updates suchen zu lassen, es kommt jedesmal “fehler bei firmware ueberpruefung”, auch nach einem router neustart kein erfolg. Aktuelle FW V1.0.4...
- Jun 23, 2022
You can manually update the firmware.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Jun 23, 2022Guru - Experienced User
- mschnrmJun 24, 2022AspirantOk! Thanks, I will try it like that!
- mschnrmJun 25, 2022AspirantI managed to push the update through routerlogin, it updated successfully.
However, the nighthawk app now has issues connecting to the router, if i manage to establish a connection, it wouldn’t load router settings, keeps freezing with “please be patient”..- plemansJun 25, 2022Guru - Experienced User
If you're on iOS, make sure to turn of icloud relay and private mac/ip address. they can mess up the app working properly
