olwe1822
Nov 26, 2021Aspirant
USB Control Center findet Router R6400v2 nicht
Windows 10 PC, Router R6400v2, download und Installation fehlermeldungsfrei, USB Control Center startet, kein Router und auch keine Möglichkeit die Buttons auszuwählen (z.B. Netzwerk scannen). Hat j...
- Nov 30, 2021
USB Control Center Software does not detect R6400v2. Opening the software by double click to icon on desktop the window opens but window is blank (does not show any router).
May be the solution is as following: I tried to solve this issue by myself and open the Control Center from the menue bottom right.
Doing that by these method the software displayed the router and all other things done later on worked okay.
If that is a plausible explanation than it could be helpful to give a hint in the installation routine, that the software cannot be opened a second time by clicking on icon. The standard installation method is to start software during booting the PC.
Nevertheless many thanks for your so fast interest in my issue! That motivates me to use more often communities. Thanks a lot!
Oliver
michaelkenward
Nov 29, 2021Guru - Experienced User
