tosmith1
Jul 26, 2019Tutor
Netgear armor
How to remove netgear armor. After installing and activating, my printer started printing pages of ascii characters. Absolutely no faq help how do I uninstall this piece of SPAM and spyware.
- Jul 29, 2019
Thanks for the heads up, but I had already figured out how to disable the unwanted software.
I was given no option weather to install or not. What no one can tell me is how to uninstall this add on that will generate more income for netgear and bitdefender who has no info on their site except advertising more products.
I would appreciate if you would tell netgear NOT to install add on without a way to uninstall.
DexterJB
Jul 29, 2019NETGEAR Moderator
Hi tosmith1, welcome to the community! The link below provides the steps on how to enable/disable Armor if you want to isolate the issue.
Please let us know how that goes. Also, we'd love to help fix it if that is indeed what caused the issue.
Dexter
tosmith1
Jul 29, 2019Tutor
