AlzarriJoseph
Dec 23, 2021Follower
R6300v2 / keine volle LAN-Leistung 1GB (und auch das WLAN schwächelt)?
Firmware-Version: 1.0.4.52_10.0.93 Hallo Cummunity Ich habe eine GB-Leitung und wenn ich meinen PC direkt am Modem (UPC) anschliessen, dann bekommen ich so zwischen 800 - 950 Mbit's. Wenn ich das Net...
Dec 23, 2021Guru - Experienced User
The R6300v2 isn't going to hit gigabit speeds over its WAN-LAN. It might hit 700-800mbps over wired wan-lan.
What modem/gateway is it connected to?
Try factory resetting the r6300v2 back to defaults. Then during setup, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled. Those processes require traffic to be inspected and the r6300 doesn't have the cpu to inspect traffic at full gigabit speeds.
Wireless won't even get close to gigabit. The 280mbps that you're hitting over 5ghz is about what you can expect from its wireless. (and is actually faster than I'd expect for that router)
