OrbiWlanKenobi
Feb 22, 2025Aspirant
RB760 / RB40 Satellit mit RBR760 verbinden
Ist es möglich einen RB40 Satelliten mit einem RBR760 Router zu verbinden? Der Router findet den Satelliten leider nicht und dieser zeigt dauerhaft Magenta an. Danke
- Feb 25, 2025
Hello OrbiWlanKenobi,
Welcome to the NETGEAR Community!
The RBR760 is not compatible with the RBS40. The RBR760 can be used with the RBSV40, RBS50Y and the RBS760. Please note that using the RBS40V or the RBS50Y will result in degraded network performance.
Please navigate to the link below for more information about your RBR760's satellite compatibility:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Best,
Kevin
Community Team
KevinLiT
Feb 25, 2025NETGEAR Moderator
Best,
Kevin
Community Team
OrbiWlanKenobi
Feb 25, 2025Aspirant
Thx for the information!
Thought all Orbis work together but now i know better.
Greetings
Greetings
