uplinkal's avatar
uplinkal
Follower
Mar 06, 2020
GS724T(24-port)
I have a Netgear GS724T router showing V1 2.3._0603. Device was purchased at a bankruptcy sale a few years ago and is working well, but I was trying to find out whether any firmware upgrades were available (or even necessary). There is no serial number label on the device, only a label with a MAC address (00-0F-B5-36-0D-56). I would also presume that the serial number label has fallen off or was removed for some reason before I acquired it. I am presuming that the V1 is Version 1 but I am not certain of that. This number matches the number found when I run SmartWizard Discovery (just no serial number).
If there are any formware upgrades where are they located (for downloading) and is there a certain progression I must follow since I do not know the exact version or serial number? This thing works great and I don't want to screw it up.
Looking for any help and advice I can get. Thanks.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    uplinkal,
    Welcome to the community! :)
    The exact switch model that you have is a GS724Tv1 and it is already on the latest firmware v1.2.3_0603.  As reference, try to download firmware v1.2.3 here then extract it.
    To learn more about the GS724Tv1, you can access its documentation here.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
