FURRYe38's avatar
5Ghz and Large File Size Upload Experiences
Asking to see if users can test uploading mid to large size files (800Mb to 10Gb) thru the CAX30 5Ghz Wi-Fi system.
Please post what devices you use,
Wi-Fi adapter brand and model,
What FW version loaded on CAX30,
Is Smart Connect and AX mode enabled or disabled,
Channel used on the CAX30,
Advanced Wi-Fi configuration settings
and the size of files used in the upload.
Did it work or no? And if no, please give details.
Upload your files to a cloud service or share of your choosing. Remove files as needed after testing.
Thank you.
No RepliesBe the first to reply
