dave8
Apr 18, 2023Aspirant
CAX30 - Intermittent Internet
The problem still the same: Some of my devices not able to connect to the internet. I periodically have to reboot my router. My Netgear router status tells me the connection is Poor. I've also re...
- Apr 28, 2023
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 21, 2023Guru - Experienced User
Any progress on this?
dave8 wrote:
The problem still the same: Some of my devices not able to connect to the internet. I periodically have to reboot my router. My Netgear router status tells me the connection is Poor. I've also reset my router but still the same. Xfinity shows there is a problem with this router model. See attachment for details regarding Netgear status.
