dave8
Apr 18, 2023Aspirant
CAX30 - Intermittent Internet
The problem still the same: Some of my devices not able to connect to the internet. I periodically have to reboot my router. My Netgear router status tells me the connection is Poor. I've also re...
- Apr 28, 2023
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
dave8
Apr 27, 2023Aspirant
Looks like this may be stable now. I had my ISP check the items you mentioned and they did something to correct the problem.
Apr 28, 2023Guru - Experienced User
Enjoy. 📡
