ChristineT
Nov 13, 2024NETGEAR Employee Retired
CAX30 V2.2.4.2 Firmware Update now available for testing
Hello CAX30 Beta Testers,
Firmware Download:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/QU000001Qkuf/xmHYnrcHGeBXmOKhp7zc_MkOrI3XKGaKXut4vYf_XLE
Release Notes:
Security imp...
Nov 16, 2024Guru - Experienced User
Ok, v2.2.4.2 loaded and installed, factory reset and setup from scratch.
Found a couple of odd issues during the setup routing, 1. Using MS EDGE browser, After the factory reset when in with a wired PC win 10 and disabled all but 4 logging options and after hitting the apply button, the web page didn't refresh at all and thought I didn't select the APPLY button or incorrectly selected it, selected the APPLY button a couple of time didn't refresh the page so I selected a different menu item and the middle circle animation appeared and that was it. Did not clear after that and selecting any other WEB UI menu item failed to be processed by the browser. Seemed like the WEB UI Server hung up and stopped responded so I had to power off the CAX30 then back ON to regain access. 2. After changing the router IP address 192.168.0.1 and setting a new DCHP IP address range, .100 to .150 and then selecting the APPLY button, seem to take near 30 seconds for the modem and browser to update to begin the reboot process. Not sure if this maybe a performance issue or something different. May cause users to complain about wait time or not need the browser refresh giving indication of the change taking effect. Other than those two items so far.
Just got it online with ISP.
In Gateway mode.
Will monitor and observe over next few days.
Nov 26, 2024Guru - Experienced User
One issue I'm now seeing, seems like when I added a EAX80 with most current version of FW,
It's not being seen on the NH app v2.41.0.34 or being tiled as Network Map to select for the EAX80 from the CAX30s main home page.
I can access it using it's static IP address (192.168.0.80) I set on the EAX80 that is out side of the CAX30s default IP address pool range which I changes to smaller size.
EAX80 shows it's connected and LEDs in front are all WHITE.
I don't see the EAX80 listed on the NG app and I believe it's not appearing on the CAX30 web ui, I need to confirm this again.
Can this be a Orbi app issue or a CAX30 FW issue?
Prior testing was with the EAX80 and CAX80 RS600 and it worked there.
- FURRYe38Nov 27, 2024Guru - Experienced User
So after I got home, I checked the NH app and CAX30 ui and saw that the EAX80 was being displayed in both areas. I was at work earlier so I was remote. Not sure if Anywhere Access and remote impacts how the EAX80 is being seen or displayed. Otherwise, it is working at home.
- FURRYe38Dec 08, 2024Guru - Experienced User
Checking someting today with the WEB UI, using MS Edge in Windows 11, on the basic tab/connected device page,
The column headers for each column, they are selectable however are not doing anything when selected. Would be a great feature to have this ability to sort the columns with any of these headers:
Especially by IP Address. 😉
- FURRYe38Dec 25, 2024Guru - Experienced User
So after having the CAX30 in gateway mode since beta FW was loaded, I had setup a Orbi 960 series system in AP mode and shut off the CAX30s radios. All has been working well. Today I wanted to use the Orbi 960 in router mode and configure the CAX30 for modem only mode. I configured the 960 for router mode and disconnected it from the CAX30 prior to setting the CAX30 to modem mode. Disconnected all other LAN devices from the CAX30 and connected them to the RBR960. I connected on windows laptop to the CAX30 and using FireFox browser, went in and set the router mode from Yes to NO and selected apply. After about 15-30 seconds I expected the front LEDs to all turn OFF sans the power LED. I noticed that the 2.4 and 5Ghz radio LEDs were ON along with the laptop PC. I disconnected the laptop as the web ui said it was now rebooting the CAX30. Still front LEDs were ON for the radios. I had noticed that the front LEDs finally all went OFF then the wifi radios came back ON, then the downlink LEDs started blinking then the uplink and finally the Internet LED. Wifi LEDs remained ON and blinked.
I went head and connected the RBR960 router to port #1 and it got internet services. I checked the RBRs WAN port status and it had a WAN side IP address from my ISP, Sparklight. RBR reported having GOOD internet services.
CAX30 WIFI LEDS remain on. I pulled the power cord from behind the CAX30 for 20 seconds then plugged back IN. As the modem came online, WIFI LEDs are ON.
I pressed the front WiFi enable disable button on the CAX30 for 5 seconds and both WiFI LEDs turned OFF. I'll leave it for now.
I'm out of time to troubleshoot this more. I took a video of this happening as well.
