stacey_
Aug 16, 2023Aspirant
Continue to have problems with Google Home connection related to router
I have a Google Home speaker that continues to have connection issues related to my router. The speaker works when I connect it to other routers, so I'm fairly certain at this point that it is relate...
Aug 16, 2023Guru - Experienced User
What channel configurations are currently set on the router for both radios?
What are the basic tab and advanced wireless settings tabs currently configured for?
Does this happend with Smart Connect disabled?
Does this happen with AX mode disabled under basic tab/wireless settings?
Whats the distance between the CAX30 and this one device?
Is this the only device your having problems with?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
stacey_
Thanks for your quick reply!!!
In response to your questions:
Wireless Network (2.4GHz b/g/n/ax) = channel: auto
Wireless Network (5GHz a/n/ac/ax) = channel: 44
Everything is currently checked in advanced wireless settings.
Does this happen with Smart Connect disabled?
I tried disabling it and didn't notice a difference. I can give this another shot as I currently have Smart Connect enabled.
I have not tried this. I will try this next.
They are in the same room, not very far away.
It's only a problem with the Google Home speakers (I have more than one).
I've reset and restared multiple times. I do not have a wired PC, though.
- FURRYe38Aug 16, 2023Guru - Experienced User
In response to your questions:What channel configurations are currently set on the router for both radios?
Try channels 1 and 40.
Try disabling Airtime Fairness option here.
Uncheck the 20/40Mhz check box as well.
How many do you have?
Have you turned OFF all of these devices accept for one to see if problem continues?
- stacey_Aug 16, 2023Aspirant
UPDATE but still not resolution 😞
I tried disabling Smart Connect and unchecking AX mode. After a restart/reset, Google Home worked for about 5 minutes before losing connection again...
Yes, I've tried everything! The problem is apparent in the Google Home app, too. It started working again right now. It just goes in and out... for no apparent reason.
