gadjoman
Apr 07, 2023Initiate
Re: beta cax 30
The connection always fluctuates and not stabile. It works for a few hours but then the speed drop. On the mobile phones the wi-fi disconnects and for the other devices speed is weak.I did multiple f...
Apr 07, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
I use manual Channels 1 and 40 here. 40Mhz channel with only.
Smart Connect enabled.
Armor and Traffic Meter not enabled.
DCHP IP address pool size set for .100 to .200.
