RickyDan78
Apr 15, 2023Tutor
V1.4.12.2 Not off to a great start.
So V1.4.12.2 was installed on my CAX30 overnight between Thursday 4/13 and Friday 4/14. Immediately we have issues with internet in our house. Phone and tablets have trouble loading pages. When toggle...
Apr 16, 2023Guru - Experienced User
What devices are you speed testing on? Speed testing with NH app or Ooklas installable speed test app?
Do ethernet connected PC speeds look ok?
What channels are you using? I'm using 1 and 161 here.
After v1.4.12.2 was on your CAX30, Had a factory reset and setup from scratch been performed afterwards? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Im also on v.12.2
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- NeodymiumApr 17, 2023TutorThe devices I’ve chiefly done the speed tests are an iPhone 12 Pro Max, Mac mini (M1, 2020), and a MacBook Pro (2016).
The first two devices are Wi-Fi 6, and the latter Wi-Fi 5. The iPhone and MBP showing similar Wi-Fi speeds (120-170mbps) for both web and app versions from Ookla, but the NH app (on iPhone only) tests at an average of 400mbps. The Mac mini is connected via gigabit ethernet and currently bats a solid 930mbps (Ookla web and app) where it performed slightly better at a solid 970mbps on versions prior to 1.4.11.2.
I had done a reset back when I had to manually install 11.2, but not for 12.2 yet. I’ll eventually write back with the status and logs as well!- FURRYe38Apr 17, 2023Guru - Experienced User
Lets try a FR and setup from scratch.
Be sure to not enable any Armor, SPC or Traffic Meter of the bat.
I'm seeing this on my iPhone 12 Pro Max with the NH app:
Was told this was max we'll see thru the NH app. Wired speeds with a ethernet connected PC gets me near my 900Mpbs and to spec 50Mpbs on the up though. I have a RAXE500 in wireless bridge mode connected to the 5Ghz radio on the CAX30. I see to spec speeds thru it as well.
Please also post the modems connection status and event log page.
- RickyDan78Apr 17, 2023Tutor
Thank you for your response. Just performed the factory reset again. Let it come back up, and power cycled for 60 seconds. Logged back in and performed complete set up from scratch.
2.4 band is set to channel 1
5 band is set to channel 161
(Netgear support and I worked on setting the best channels in my location recently, and we have found these work best here)
Address pool range has now been set to 100-200.
After this, wired to port 4 of the router, speeds (Ookla website) are reading 320Mbps down, 20-22Mbps up.
Below taken with Ookla installed app:
2.4 - between 74-105Mbps down, 20-22Mbps up.
5 - between 701-747Mbps down, 20-22Mbps up.
Before factory reset some apps would not load, Netflix & Discovery+ would not load movies. Since FR they seem to be working fine We will continue to monitor this daily.
Paste of event log:
Time Priority Description 2023-04-17 16:30:11 Critical (3) UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-04-17 16:30:11 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:33 Notice (6) Honoring MDD; IP provisioning mode = IPv6 1970-01-01 00:00:27 Critical (3) UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-04-17 16:26:23 Critical (3) UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 2023-04-17 16:26:23 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:02:45 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:02:42 Critical (3) UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:02:19 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:41 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Paste of Cable Connection:
<tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 447000000 Hz Locked Connectivity State OK Registration Complete Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectabables 1 Locked 256 QAM 4 447000000 Hz -4.-5 dBmV 44.3 dB 0 0 2 Locked 256 QAM 1 429000000 Hz -4.-5 dBmV 44.2 dB 0 0 3 Locked 256 QAM 2 435000000 Hz -4.-5 dBmV 44.2 dB 0 0 4 Locked 256 QAM 3 441000000 Hz -4.-8 dBmV 44.1 dB 0 0 5 Locked 256 QAM 5 453000000 Hz -4.-4 dBmV 44.2 dB 0 0 6 Locked 256 QAM 6 459000000 Hz -4.-4 dBmV 44.3 dB 0 0 7 Locked 256 QAM 7 465000000 Hz -4.-4 dBmV 44.2 dB 0 0 8 Locked 256 QAM 8 471000000 Hz -4.-5 dBmV 44.2 dB 0 0 9 Locked 256 QAM 9 477000000 Hz -4.-6 dBmV 44.1 dB 0 0 10 Locked 256 QAM 10 483000000 Hz -4.-5 dBmV 44.2 dB 0 0 11 Locked 256 QAM 11 489000000 Hz -4.-8 dBmV 43.9 dB 0 0 12 Locked 256 QAM 12 495000000 Hz -4.-5 dBmV 44.1 dB 0 0 13 Locked 256 QAM 13 501000000 Hz -4.-6 dBmV 44.0 dB 0 0 14 Locked 256 QAM 14 507000000 Hz -4.-9 dBmV 43.8 dB 0 0 15 Locked 256 QAM 15 513000000 Hz -4.-4 dBmV 44.1 dB 0 0 16 Locked 256 QAM 16 519000000 Hz -4.-8 dBmV 43.9 dB 0 0 17 Locked 256 QAM 17 525000000 Hz -5.-4 dBmV 43.5 dB 0 0 18 Locked 256 QAM 18 531000000 Hz -5.0 dBmV 43.6 dB 0 0 19 Locked 256 QAM 19 537000000 Hz -5.-4 dBmV 43.4 dB 0 0 20 Locked 256 QAM 20 543000000 Hz -5.-5 dBmV 43.4 dB 0 0 21 Locked 256 QAM 21 549000000 Hz -5.0 dBmV 43.7 dB 0 0 22 Locked 256 QAM 22 555000000 Hz -5.-6 dBmV 43.2 dB 0 0 23 Locked 256 QAM 23 561000000 Hz -5.-8 dBmV 43.0 dB 0 0 24 Locked 256 QAM 24 567000000 Hz -5.-6 dBmV 43.2 dB 0 0 25 Locked 256 QAM 25 573000000 Hz -5.-8 dBmV 43.0 dB 0 0 26 Locked 256 QAM 26 579000000 Hz -5.-6 dBmV 43.2 dB 0 0 27 Locked 256 QAM 27 585000000 Hz -5.-8 dBmV 43.0 dB 0 0 28 Locked 256 QAM 28 591000000 Hz -5.-7 dBmV 43.1 dB 0 0 29 Locked 256 QAM 29 597000000 Hz -5.-9 dBmV 42.9 dB 0 0 30 Locked 256 QAM 30 603000000 Hz -6.-4 dBmV 42.5 dB 0 0 31 Locked 256 QAM 31 609000000 Hz -6.0 dBmV 42.9 dB 0 0 32 Locked 256 QAM 32 615000000 Hz -6.-5 dBmV 42.5 dB 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1> Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 51.3 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 51.5 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 51.3 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 51.8 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords 1 193 Non-Primary 803.6 MHz 148 ~ 3947 6497116 0 2 0 Other 0 MHz 0 ~ 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power 1 Other 0 MHz 0 ~ 0 0 0 dBmV 2 Other 0 MHz 0 ~ 0 0 0 dBmV - FURRYe38Apr 17, 2023Guru - Experienced User
Ok, though power to the modem is with in specs, could check to see if the ISP would raise the power just a bit. Maybe up to -1 to 0db?
Correctables and un-correctables is zero so thats good.
Any Criticals seen in the Event logs needs to be reviewed by the ISP. Have NG check these as well. Includes any Warnings or Errors as well if seen here.
See how it goes and keep us posted.
- RickyDan78Apr 17, 2023TutorFURRYe38
This will sound strange, but my speeds continue to test great, however news apps and videos will not open when I am using the WiFi. (Android phone) If I toggle to cell data the apps and or videos load immediately. I would think that good speeds and pings would mean good connection.
This did not happen before the beta firmware. 1.4.11.2 had much slower speeds however no loading issues. Just thought I would mention, as if this is due to the firmware, I am unable to use this for daily activities.
