RickyDan78
Apr 15, 2023Tutor
V1.4.12.2 Not off to a great start.
So V1.4.12.2 was installed on my CAX30 overnight between Thursday 4/13 and Friday 4/14. Immediately we have issues with internet in our house. Phone and tablets have trouble loading pages. When toggle...
Apr 16, 2023Guru - Experienced User
What devices are you speed testing on? Speed testing with NH app or Ooklas installable speed test app?
Do ethernet connected PC speeds look ok?
What channels are you using? I'm using 1 and 161 here.
After v1.4.12.2 was on your CAX30, Had a factory reset and setup from scratch been performed afterwards? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Im also on v.12.2
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
RickyDan78
Apr 17, 2023Tutor
Thank you for your response. Just performed the factory reset again. Let it come back up, and power cycled for 60 seconds. Logged back in and performed complete set up from scratch.
2.4 band is set to channel 1
5 band is set to channel 161
(Netgear support and I worked on setting the best channels in my location recently, and we have found these work best here)
Address pool range has now been set to 100-200.
After this, wired to port 4 of the router, speeds (Ookla website) are reading 320Mbps down, 20-22Mbps up.
Below taken with Ookla installed app:
2.4 - between 74-105Mbps down, 20-22Mbps up.
5 - between 701-747Mbps down, 20-22Mbps up.
Before factory reset some apps would not load, Netflix & Discovery+ would not load movies. Since FR they seem to be working fine We will continue to monitor this daily.
Paste of event log:
| Time | Priority | Description |
| 2023-04-17 16:30:11 | Critical (3) | UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-17 16:30:11 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 1970-01-01 00:00:33 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 1970-01-01 00:00:27 | Critical (3) | UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 1970-01-01 00:00:25 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-17 16:26:23 | Critical (3) | UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2023-04-17 16:26:23 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 1970-01-01 00:02:45 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 1970-01-01 00:02:42 | Critical (3) | UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 1970-01-01 00:02:19 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 1970-01-01 00:00:41 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Paste of Cable Connection:
| <tabindex=-1>Startup Procedure</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream OFDM Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- FURRYe38Apr 17, 2023Guru - Experienced User
Ok, though power to the modem is with in specs, could check to see if the ISP would raise the power just a bit. Maybe up to -1 to 0db?
Correctables and un-correctables is zero so thats good.
Any Criticals seen in the Event logs needs to be reviewed by the ISP. Have NG check these as well. Includes any Warnings or Errors as well if seen here.
See how it goes and keep us posted.
- RickyDan78Apr 17, 2023TutorFURRYe38
This will sound strange, but my speeds continue to test great, however news apps and videos will not open when I am using the WiFi. (Android phone) If I toggle to cell data the apps and or videos load immediately. I would think that good speeds and pings would mean good connection.
This did not happen before the beta firmware. 1.4.11.2 had much slower speeds however no loading issues. Just thought I would mention, as if this is due to the firmware, I am unable to use this for daily activities.
