lulumis
Feb 15, 2021Aspirant
About GC510P temperture
Hello everyone! Anyone has bought the GC510P? This swith has no fan inside, if the temperture will be so high when the POE ports fully worked? My MS510TX always works on 65℃ and it has no POE...
schumaku
Feb 15, 2021Guru - Experienced User
lulumis wrote:My MS510TX always works on 65℃ and it has no POE function.
...however this is a MultiGig and 10G switch > 25W
A fully loaded GC510P does take some 10.5 W, assuming a 5% quality power supply add some 7.5W overhead we're at 18W, and no energy intense GbE ech only so you should be fine.
lulumis
Yes, the GC510P's Max power is 10.3W
But I don't know whether I should buy the GC510PP. It has 1 fan inside
