schumaku
Apr 11, 2019Guru - Experienced User
Insight Switch - Port Monitoring in Insight Mode
As the port monitoring options on Insighht are rather limited, we would kindly ask Netgear to allow access to
Monitoring -> Ports
Switch Statistics
Port Statistics
Port Detailed Statis...
MrJoshW
Apr 11, 2019NETGEAR Employee Retired
Hello,
These are already located on the local GUI of the GC switches. If the device is connected and being managed through Insight the user would need to log into the switch and toggle the switch to local mode in order to re-enable these features and use them for testing purposes.
- schumakuApr 11, 2019Guru - Experienced UserThat's not what we're looking for - troubleshooting and more details while the switch is Insight managed.
This information is available anyway, no reason to not display it.
Oh, IP and ARP tables are required to be made visible in the Web UI while Insight management is up, too
Zero interest for breaking a leg to see the hospital from inside!
