BretD
Jul 09, 2018Administrator
New 52-port Insight Managed Switches Ready from the Door to the Core!
NETGEAR’s portfolio of Insight Managed Smart Cloud Switches is expanding with our biggest models yet, 52 ports ready to serve your growing small and medium business needs. We’d love to see what you think in the comments below.
The NETGEAR® Insight Managed Smart Cloud GC752XP is the first 52-port Gigabit Ethernet PoE+ Switch from NETGEAR with anytime, anywhere remote/cloud management. Using either the NETGEAR Insight mobile app or the Insight Cloud Portal you can easily setup, monitor and manage your Insight Managed Switches, Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR GC752XP features 48 copper Gigabit Ethernet PoE+ ports, 2 SFP 1G and 2 SFP+ 10G Fiber ports for maximum flexibility and connectivity in your network. With its remote cloud manageability, 505W PoE total budget, and advanced L2+/L3 Lite features, it’s the most versatile switch on the market for any environment!
More about the GC752XP:
- Insight Managed Smart Cloud Switch using the NETGEAR Insight app or intuitive Insight Cloud Portal for easy setup and anywhere monitoring and management; remote/cloud management from the app is free for first two devices; after that, a subscription is required per additional device (no additional hardware required).
- 30-day free trial of Insight Premium including the Insight Cloud Portal included with every 28-port and above Insight Managed Smart Cloud Switch.
- All-inclusive connectivity & PoE+ with 48 copper Gigabit Ethernet PoE+ ports (505W), 2 SFP Gigabit fiber ports and 2 SFP+ 10-Gigabit fiber ports
- Advanced L2+/L3 Lite switching capabilities (VLANs, LAG, QoS, IGMP Snooping, Multicast, Spanning Tree, ACLs, Static Routing, STP/RSTP, etc.) – to ensure a secure, reliable, efficient, and capable network
- Advanced VLAN management (Voice, Video, VoIP, protocol- and MAC-based, Dynamic using 802.1x Guest VLAN) for traffic segmentation and secure segregation between guest, business, and voice/video networks
- Industry-leading 5-year limited hardware warranty
Need 52 ports but not PoE? In that case, the GC752X Insight Managed Smart Cloud 52-port switch is ready to server your network.
GC752X |
GC752XP |
Cloud/Remote Management |
Yes |
Yes |
Mobile/app and cloud portal management |
Yes |
Yes |
Advanced L2+ Smart Switch Features |
Yes, L2+/L3 Lite |
Yes, L2+/L3 Lite |
Number of Gigabit Ethernet ports |
48 |
48 |
Number of Gigabit SFP ports |
2 |
2 |
Number of 10G SFP+ ports |
2 |
2 |
Fan(s) |
1 (load-balanced) |
3 (load-balanced) |
PoE/PoE+ ports |
N/A |
48 PoE+ |
PoE power budget |
N/A |
505W |
Rack-mountable |
Yes |
Yes |
Support |
More Info: |
marked as solved.
1 Reply
- BretDAdministrator
marked as solved.
