GSICT
Apr 28, 2022Aspirant
Two routers into one switch
Essentially connecting two routers into one switch. I have a GS752TPP in a secondary cabinet fed from the first cabinet. There are two incoming connections into the cabinet giving DHCP. O...
GSICT
The nearest similar situation I have come across is below so it seems as if this is feasible. However, the solution does not seem to be clear and I need a little guidance on whether the Netgear can do this and some simple instructions on how?
