GSICT
Apr 28, 2022Aspirant
Two routers into one switch
Essentially connecting two routers into one switch. I have a GS752TPP in a secondary cabinet fed from the first cabinet. There are two incoming connections into the cabinet giving DHCP. O...
JeraldM
Apr 29, 2022NETGEAR Employee Retired
Welcome to the community!
Could you also post some screenshots on Switching > VLAN > Advanced > VLAN Membership and Port PVID Configuration for the two VLANs?
JeraldM
NETGEAR Community Team
GSICT
May 04, 2022Aspirant
Hi
Attached jpg for the Switching > VLAN > Advanced > VLAN Membership and Port PVID Configuration for the two VLANs.
Hopefully the issue will be spotted.
Thank you
- JeraldMMay 04, 2022NETGEAR Employee Retired
Hi GSICT,
Thanks for attaching the screenshot. The configuration looks fine and both VLANs are isolated.
Are there more affected ports in which they switch their states? Also, what devices are connected on ports 2, 12, and 44?
JeraldM
