Alberto_G
Jun 08, 2021Aspirant
BR500 - Instant VPN Router
I am the owner of a small business in Italy and its IT manager and was very excited about the Netgear BR500 and the Insight product linup. I have purchased it together with several insight access poi...
- Jun 20, 2021
Yesterday - I have noticed the VPN light of my router on! It seems that an update on the Insight app has solved all issues. I could reset all - tested on two pc's and looks like all is working fine. Hope the connection will be up and stable... if this is due to the interest and help of one of the Netgear tech support I have tried to communicate with, thanks a lot!
schumaku
Jun 08, 2021Guru - Experienced User
Retired_Member please.
- Alberto_GJun 20, 2021Aspirant
- schumakuJun 20, 2021Guru - Experienced User
Hard to imagine just the App update does have changed much. Cloud access and VPN LED are mostly a hit and miss on the BR500's I have at hand here for some months. During the recent weeks, no luck to get these up here....
