DashWifi
Jun 09, 2018Follower
How to Use NETGEAR Insight Management App with Orbi – Tips and Resources
Hi all,
This might sound as a very stupid question, I currently use a ORBI RBR50. Unfortunately, the ORBI doesn't have a possibility to use Insight Premium to manage my network. As I'm reading ...
DaneA
Jun 11, 2018NETGEAR Employee Retired
Hi DashWifi,
Welcome to the community! :)
The GC110 is not a router. It is a smart switch that can be managed via the Insight app. There is no option to monitor the websites being browsed using the Insight App.
About your RBR50 that is set as router mode, you may want to use the Orbi app. With the Orbi app, you can enable Circle with Disney Smart Parental Controls for you to manage content and time online. Kindly check the supported functions of the Orbi app on the link below:
What functions can I manage using the Orbi app?
DaneA
NETGEAR Community Team
