blacknell
Jan 21, 2022Guide
GS110TPP repeatedly reported as disconnected after firmware upgrade
My switch is repeatedly being reported as disconnected. However, it is still working as a switch. This only started happening after a firmware upgrade this week. A power cycle does force a re...
DaneA
Mar 20, 2022NETGEAR Employee Retired
As far as I have checked, there is no issue pertaining to GS110TPP that is repeatedly being reported as disconnected in Insight.
Since then I notice there has been a new release 7.0.9.5 but the release notes make no mention of my issue so I'm not going to upgrade until I hear specifically it is fixed.
We could only know if we try to update the GS110TPP firmware to the latest version which is v7.0.9.5 then observe if the switch will again be repeatedly being reported as disconnected in Insight.
If the same problem occurs, I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
NETGEAR Community Team
blacknell
Mar 20, 2022Guide
I don't think I can open a ticket as my device is out of date?
I will try the suggestion
